Decimal Comma mix up
I am getting rather annoyed with the mixed display. On the dashboard it correctly shows the comma as a thousands separator and then a dot as the decimal point. However, if I go into invoices it swaps.
What gives?
Are you using the web or desktop app?
Which currency and country is your company set to?
Web app
Euro, Ireland
@david can you please advise?
Just to note, you may want to consider sending an email to [email protected] to follow up on this.
