Anyone had any experince getting past the setup page using hostinger shared hosting?
I had a version running on PHP 7 and that was fine, I recently updated my PHP to 8.1 so I could install the new v5 on a new subdomain to make sure I didn’t overwrite anything.
All is well with the install, so i proceed to I setup a empty db inside hostinger and noted the credentials.
Then on the invoiceNinja setup page I input all the db creds and press test. It says Sucess! Yay.
Then I add some brand new user credentials in and press submit.
It then throws an error saying it cannot connect to the database.
Ive checked the creds using phpmyadmin and they are all correct.
Any ideas what the issue could be here? Been at this for hours
Error Output:
ERROR 1045 (28000): Access denied for user ‘u63127_Ninja’@‘::1’ (using password: YES)
