Hi, I have successfully migrated data from V4 to V5 but can see the following errors when doing the following command: ninja:check-data
2021-01-31 01:55:02 2021-01-31 01:55:02 Running CheckData...
2021-01-31 01:55:02 # 10 B H Ltd - 0000 - Balance Failure - Invoice Balances = 375 Client Balance = 55.000000 Ledger Balance = 55.000000
2021-01-31 01:55:02 # 11 S D - 0001 - Balance Failure - Invoice Balances = 5 Client Balance = 0.000000 Ledger Balance = 0.000000
2021-01-31 01:55:02 # 12 G D - 0002 - Balance Failure - Invoice Balances = 40 Client Balance = 0.000000 Ledger Balance = 0.000000
2021-01-31 01:55:02 # 14 P D - 0004 - Balance Failure - Invoice Balances = 2 Client Balance = 0.000000 Ledger Balance = 0.000000
2021-01-31 01:55:02 # 15 L R Ltd - 0005 - Balance Failure - Invoice Balances = 52.98 Client Balance = 0.000000 Ledger Balance = 0.000000
2021-01-31 01:55:02 5 clients with incorrect balances
2021-01-31 01:55:02 0 clients with incorrect invoice balances
2021-01-31 01:55:02 0 clients with incorrect paid to dates
2021-01-31 01:55:02 B H Ltd - 10 - calculated client balances do not match 375.000000 - 55.
2021-01-31 01:55:02 S D - 11 - calculated client balances do not match 5.000000 - 0.
2021-01-31 01:55:02 G D - 12 - calculated client balances do not match 40.000000 - 0.
2021-01-31 01:55:02 P D - 14 - calculated client balances do not match 2.000000 - 0.
2021-01-31 01:55:02 L R Ltd - 15 - calculated client balances do not match 52.980000 - 0.
2021-01-31 01:55:02 5 clients with incorrect client balances
2021-01-31 01:55:02 0 contacts without a contact_key
2021-01-31 01:55:02 0 clients without any contacts
2021-01-31 01:55:02 0 clients without a single primary contact
2021-01-31 01:55:02 0 users with duplicate oauth ids
2021-01-31 01:55:02 1 failed jobs
2021-01-31 01:55:02 Done: FAILURE
February 1, 2021, 5:39pm
Are you able to review the data in v4/v5 to see where the differences are?
@david any thoughts on how to best debug this?
david
February 1, 2021, 8:04pm
3
@DylanPedro can you confirm the migration completed? in v5, go to storage/logs/laravel.log it will have the output of the migration. You’ll want to check that it got all the way through the entities and finished with a Completed notification.
Hi David,
Looks like it did complete:
[2021-01-31 13:46:40] production.INFO: Importing account
[2021-01-31 13:46:40] production.INFO: Importing company
[2021-01-31 13:46:40] production.INFO: the path /storage/go3MNtaSEezDJwpWJPEnCJr8coYuPalZ/BCnSvsmjNkdN03yRBFijWgqAxUcM5vQ0UXMBTNwx.png
[2021-01-31 13:46:40] production.INFO: Importing users
[2021-01-31 13:46:40] production.INFO: Importing payment_terms
[2021-01-31 13:46:40] production.INFO: Importing tax_rates
[2021-01-31 13:46:40] production.INFO: Importing clients
[2021-01-31 13:46:41] production.INFO: Importing company_gateways
[2021-01-31 13:46:41] production.INFO: Importing client_gateway_tokens
[2021-01-31 13:46:41] production.INFO: Importing vendors
[2021-01-31 13:46:41] production.INFO: Importing projects
[2021-01-31 13:46:41] production.INFO: Importing products
[2021-01-31 13:46:41] production.INFO: Importing credits
[2021-01-31 13:46:41] production.INFO: Importing invoices
[2021-01-31 13:46:42] production.INFO: Importing recurring_invoices
[2021-01-31 13:46:42] production.INFO: Importing quotes
[2021-01-31 13:46:42] production.INFO: Importing payments
[2021-01-31 13:46:42] production.INFO: Importing expense_categories
[2021-01-31 13:46:42] production.INFO: Importing task_statuses
[2021-01-31 13:46:42] production.INFO: in task statuses
[2021-01-31 13:46:42] production.INFO: finished task statuses
[2021-01-31 13:46:42] production.INFO: Importing expenses
[2021-01-31 13:46:42] production.INFO: Importing tasks
[2021-01-31 13:46:42] production.INFO: Importing documents
[2021-01-31 13:46:44] production.INFO: Completed🚀🚀🚀🚀🚀 at 2021-01-31 13:46:44
david
February 2, 2021, 1:39am
5
@DylanPedro are you able to join us on slack so we can debug further?
http://slack.invoiceninja.com
