I am trying to customize a simple thing in the header on my invoice: I want Address 2 to live on the same line as Address 1. When I look in the code I see that each company address item is embedded in its own <p>
tag:
<div id="company-address"><p data-state="encoded-html" data-ref="company_address-company.address1"><p>My street address</p></p><p data-state="encoded-html" data-ref="company_address-company.address2"><p>apt#</p></p><p data-state="encoded-html" data-ref="company_address-company.city_state_postal"><p>City, State, Zip</p></p><p data-state="encoded-html" data-ref="company_address-company.country"><p>Country</p></p></div>
I can find no place in the template customizer that allows me to output company_address-company.address1
and company_address-company.address2
in a single <p>
tag together. And I can’t find any mention of it in the docs. Can someone point me in the right direction? Thanks
November 23, 2021, 5:52am
I believe you’d need to replace the field stack with the individual field variables.
@ben is there another option?
And where is that located? When I look at the header code in the interface, I only see the wrapping elements:
<div id="header">
<div class="logo-container">
<img class="company-logo" src="$company.logo" alt="$company.name logo">
</div>
<div id="company-details"></div>
<div id="company-address"></div>
</div>
Do you mean I should just replace the company-address
div with my own, made up of the child elements?
well, that didn’t work:
<div id="company-address-div"><div data-state="encoded-html" data-ref="company_address-company.address1"></div><div data-state="encoded-html" data-ref="company_address-company.address2"></div></div>
November 23, 2021, 6:01am
6
You’d want to replace the company-address div with the individual variables you want shown.
https://invoiceninja.github.io/docs/custom-fields/#custom-fields
I just tried that, see above. And it didn’t work, at least in preview. Is there something else I need to do?
November 23, 2021, 6:33am
8
It doesn’t look like you’re using the variables, ie. $client.address1
