Customize Customer Portal and so on
Hi together,
how can i customize a Customer Portal in self hosted variant when i have more than one company behind?
So Title, Logo, Image and so on?
Thanks in advance!
You can define custom CSS for the portal, the portal should use the logo for the selected company.
Note: please make sure you’re within the terms of the license.
i checked, it seems to be ok.
But where can i change the custom css for each sites portal?
There’s an option on Settings > Client Portal
This is right, but when there is, let’s say
portal.company1.net
portal. company2.net
there is the logo of company1 and as well as all backlinks also for portal.company2.net
Are you referring to the login screen or the portal itself?
Both, sorry didn’t get any notifications about your reply.
Are the custom CSS changes not being applied?
