I’d like to customize the client portal by adding the identification number and a custom company field to the company details.
I also want to add a hyperlink to terms and conditionsin to the footer of the client portal so my customers are able to read those without opening any invoices. Is this possible on a white-labeled self-hosting v4.5.6?
You might be able to do this by adding some custom CSS. It will be at http://your.url/settings/client_portal#custom_css
Thanks for your suggestions. Do you know which css code I have to use to show identification number? As far as I know it is not possible to add a hyperlink with css.
Unfortunately no. CSS is something completely outside of my wheelhouse.
Never mind. I managed to add an extra menu item with a dropdown. So now I am happy.
