I’d planned to define a sort of Task Categories like “Category” as Dropdown-List “Conception, Creation, Design, Deploymens …”, but the option is missing in custom fields, altough everything seems to be implemented in the task-view.
Is this Custom field reserved for V4 migrations, or is it too early (maybee available in the v5-develop branch). Do you have any idea?
The column shows the right content, but not the name of the custom field. I’d expected in my example “Leistungsart”. This is also a issue in over views, where not the name but “custom 1, 2…” is shown as column title.
By the way: The column title is not named properly after its task filed name 1. Operating with a column “Custom 1” is not self-explaining at forces users to guess, what was meant.
When I do an “Invoice Project” I discover that the columns are not corresponding to the task columns set in Invoice Design (here should show up “custom task 1” instead of “Item”, or is that meant for an other purpose?)
If I am following well, the behaviour is correct? If “Empty columns” is set to Show, it’s gonna show custom columns, if it’s “Hide” it’s gonna hide, can you please confirm that part is good?
I try to subsummerize quickly what happens:
– I use Custom Field 1 for Task as shown above
– In Invoice Design I add Custom Field 1 into Task Columns
– I do a Invoice Project from Project View. I does not see the Custom Task 1 Column in Edit Invoice View, altough all Task Entries have selected Custom Task Entries (see Screenshot). Instead I see an Item Column.
– I save Invoice and the PDF is in both ways wrong:
a. When set to hide empty columns the Custom Task 1 Column does not show off, but it should because it contains data (see sample Task data screenshot).
b. When set to show empty columns it shows correctly the Custom Task 1 column but no data.
