I set the exchange rate for invoices but IN is getting the today exchange rate as a default but I want to set my own exchange rate, is this possible?
I tried to modify the exchange rate value in the Exchange Rate field int he invoice but the costs are no recalculated and If I add a new product, the exchange rate change to default
For selfhosting it’s isn’t directly supported but you could set the EXCHANGE_RATES_URL in the .env file to a script or file which returns the rates you want to use encoded as JSON.
The “exchange rate” field is in the invoice form is read only, changing it won’t change the invoice.
Ok I changed the format of the json and I validate it but nothing changed in the invoice, is there any specific place where I need to save my json file? I have it in the root of my NI installation at this moment.
FYI, after clean the cache I set the desired rate in the currencies table and now is taking the value from there. I’m not using the cron job so this would be a work around but It will better if the exchange rates files works.
