It is possible to have two currencies on the invoice? I’n from Romania and I need my invoice in RON. But BrainTree and PayPal don’t support this currency.
So I need to issue the invoice in euro for paypal/braintree and to have the total of the invoice converted in Ron.
Is it possible to do that? Can I add with zapier after the payment is made the total in ron?
For example:
the invoice of 33 euro is payid
1 euro = 4.5 ron
triggering a zap to edit that invoice and add a line Total = 138.5 ron (33 euro * 4.5)
We don’t support editing an invoice with Zapier but maybe you could create two companies and create new invoices in one company when they’re created in the other.
I’ve made some tests with zapier but I’ve got the following problems:
how do I select the currency via API ?
I’ve write in currenyc field: ron, rol, lei, @Romanian New Leu - how it appears in NinjaInvoice Form
but it sets it to euro…
how do I add the company name via API (clients name?)
I didn’t find a field named company ?
how do I use a transalted invoice?
On https://www.invoiceninja.com can I use & transalte an invoice labels? I need it to be in Romanian
it is possible to have a billingual invoice (enghlish & romanian) ?
I also need a payment link, can this be done without an invoice, just on the product from invoice ninja?
Some cart integration recommendation if you have?
Quotes are pro-forma invoices? Can I modify, read them using zapier?
I’m interesting if all this question work with https://app.invoiceninja.com and not self-hosted. If they work with self-hosted too I would appreciate it if you can tell me that also!
I’m working at the romanian transalation, I hope to be up soon. I have some questions.
Can I define a recurring product? How I can set an auto-billing from a payment link?
I can’t find how to add another company on my demo account.
If I want to disable One-Click Login, what will happen? How do I login? I can’t change the password, because is asking me for the old password that I don’t have - because I used one-click login from the start. What, I want is to login with user and password and to be able to add users.
Is there a way to download .pdf invoices from a date range?
Can’t find where to see archived invoices, archived tokens and so on.
I need to enter an invovice field with a static value (the series of the invoice, for example ABCD), I saw the customer fields for the invoice, but I don’t have value for them, is there a way to enter that invoice static value field? (like company fields)
I was able to translate the majority of the fields from settings but these 3 fields remained:
a) invoice issued to
b) invoice number
c) invoice date
if I was able to translate invoice number I’ve could enter there the series of the invoice (Invoice Series& Number): ABCD0001
Ok! Thank you. I was able to enter the series using phone field or other standard field and re-arrange them. I write here if some one has this problem in the feature.
