I’m probably doing something wrong (it’s been known to happen, heh), but I can’t seem to get currency conversions to work in the new version. I see where there’s the option to manually specify an exchange rate when entering a payment, but I’m not seeing an exchange rate in the quote or invoice page as the screenshot would suggest. And when I select a client who I’ve assigned a different currency (for example, Japanese Yen), selecting a product still shows the same numerical price, only with the Yen symbol in place of the Dollar.
As far as I know, the daily crons are fetching the rates, as they say they’re doing so when I run them manually. Did I miss something somewhere? I even manually copied 4.1.0 over thinking that maybe something got messed up in an update, but no change.
So it’s in the database, but still not showing on the invoice creation page, or converting at all.
But that value brings up another issue. By default, fixer.io converts from EUR as a base. So what’s in the database is the rate from Euros, not dollars (which would be around 110, I believe). Shouldn’t the code for getting the exchange rates from fixer.io use the users primary currency from localization settings as a base?
To show the exchange rate on the invoice you need to add a custom ‘Exchange Rate’ invoice field, it should be automatically set when choosing a product.
Made the change (was still Cache::forget(‘currencies’); in my copy) and noted the exchange rate showing right now. We’ll see what happens tomorrow, I guess.
So far so good. However, I did notice that the conversion for VND was way off. Currently, the rate is at about 22,560 (give or take), but in Invoice Ninja, it’s showing as 0.8177.
