Hi
I try to import CSV from my Bank Account. Where can I set the delimiter? For now the Mapping Table shows me only one column…
Thx
Hi
Thx
I believe the app expects a comma to be used as the delimiter.
Thx @hillel
This would be a nice feature, cause my Bank Transaction File always comes with Semicolon…
I found a description of auto-detecting feature:
https://maruan.medium.com/auto-detect-csv-enclosure-and-delimiter-in-php-b2193d34f61b
Should I make a feature request or is this function not on your wishlist at all?
Auto-detection is probably the best option. If you could please create an issue to request the feature it would be helpful.
cc @david
Yes I will do that… But not only that: I‘ve found an elegant solution, but I don’t know where to include that… Otherwise if you can assist a little, I would make a PR…
The code is:
* @param string $csvFile Path to the CSV file
* @return string Delimiter
public function detectDelimiter($csvFile)
$delimiters = [";" => 0, "," => 0, "\t" => 0, "|" => 0];
$handle = fopen($csvFile, "r");
$firstLine = fgets($handle);
fclose($handle);
foreach ($delimiters as $delimiter => &$count) {
$count = count(str_getcsv($firstLine, $delimiter));
return array_search(max($delimiters), $delimiters);
@david can you please advise?
Hi @hillel
I think I‘ve found the right place…
I just made a new feature request and a PR with a working solution. I‘ve tested with Comma-separated and Semicolon-separated CSV-Files…
Thx
Thanks for the contribution, this has been merged.
