Hi
I have for example this recurring invoice: http://screenshot.s.emp.re/0T0J2a1X3a1y
Next invoice was on 3th of February, but I just set the cronjob today.
Will that still generate the invoice for the 3th of this month?
And if not, how to correct?
Thx a lot,
Kristof Bernaert
February 12, 2017, 10:26pm
No, it would probably use today’s date. I think you’d need to manually correct the invoice.
So the cronjob runs only on the date equal to the recurring date of an recurring invoice? Right?
Does the Cronjob only looks at the date or also the time?
February 12, 2017, 11:52pm
4
The cron will send any invoices that need be sent by today, it will send past invoices which should have already been sent.
It only looks at the date.
the cron only sends? or also generates and then sends the new invoice?
seems the cron is only doing the sending of an already existing new created recurring invoice: “2017-02-13 Running SendRecurringInvoices…”
how is the recurring invoice created? Manually?
February 13, 2017, 2:49am
6
The cron creates and sends the invoice.
I have for example this: http://screenshot.s.emp.re/0f2v1b1n1r2t
I just ran the cron successfully, but no invoice is created …
February 13, 2017, 3:06am
8
Is the invoice still a draft?
February 13, 2017, 3:13am
10
Not sure, is your timezone correct on /settings/localization
Yes. Also when I see the cronlog, I see the cron executed successfully
February 13, 2017, 3:21am
12
What’s the full output of the cron?
Feb 13 14:46:02 com-linssh013.srv.combell-ops.net CRON daemon: Executing (12825) ‘/usr/bin/php /data/sites/web/itwebofficenetyyy/subsites/production-iwo/beach.sempre.blue/www/artisan ninja:send-invoices’
Feb 13 14:46:02 com-linssh013.srv.combell-ops.net CRON daemon: 1 processes running
Feb 13 14:46:06 com-linssh013.srv.combell-ops.net CRON daemon: 2017-02-13 Running SendRecurringInvoices…
Feb 13 14:46:07 com-linssh013.srv.combell-ops.net CRON daemon: Executed (12825) ‘/usr/bin/php /data/sites/web/itwebofficenetyyy/subsites/production-iwo/beach.sempre.blue/www/artisan ninja:send-invoices’
February 13, 2017, 7:27am
14
Is that all of the output? I’d expect to see how many invoices the script found.
https://github.com/invoiceninja/invoiceninja/blob/master/app/Console/Commands/SendRecurringInvoices.php#L64
You may want to echo the where SQL and try to run it manually against your db.
SELECT * FROM invoices WHERE is_deleted IS FALSE AND deleted_at IS NULL AND is_recurring IS TRUE AND is_public IS TRUE AND frequency_id > 0 AND start_date <= 20170213 AND (end_date IS NULL OR end_date >= 20170213)
This Query resulted in all (monthly & yearly) recurring invoices.
(how is distinction made between monthly recurring and yearly?)
February 13, 2017, 11:23am
16
The frequency_id designates monthly versus yearly invoices.
Is there more to the output? Maybe try running the artisan command manually from the command line.
executed from command line: ‘artisan ninja:send-invoices’
nothing happens, without any output, nor error messages
February 13, 2017, 11:39am
18
Try: php artisan ninja:send-invoices
from the root folder of the application.
That worked!
Output: http://screenshot.s.emp.re/3e2T1R1D2m30
The invoices are created but remain draft and are not sent.
February 13, 2017, 9:43pm
20
Are there any errors in your logs in storage/logs/laravel-error.log
