Hi!
I installed Invoice Ninja a few hours ago and I setup the cron with this line(ran by user www-data): * * * * * cd /var/www/kian/invoiceninja && /usr/bin/php -d register_argc_argv=On artisan queue:work --stop-when-empty
This doesnt seem to work, does anyone have an ideas on what I can do to fix this?
Also my SMTP doesnt seem to be working either. I have set it up on the .env and ran php artisan optimize after. There was no errors, so I sent a password reset request as a test but it hasnt arrived. The SMTP server works fine as I use it on other sites also.
Hi!
Ive checked on there and my .env looks ok. I sent an email and it still doesnt work. There are no errors in the laravel log, or it just hasnt updated, im not sure. The SMTP server works fine as I just tested it. Is there a way to force the log to update?
Also,
If i run cd /var/www/kian/invoiceninja && /usr/bin/php -d register_argc_argv=On artisan queue:work --stop-when-empty I dont get any errors in the console but when I go onto InvoiceNinja and click on the Error symbol it says “The Crons need to be enabled” and when I click refresh data it doesnt do anything. Do i need multiple crons or something as the instructions make it sound like you only need one of the crons on there.
It is completely separate from the queue system which sends emails. By default we have the queue set to sync - however if you wish to use database queue’s you would also need to configure some way to execute php artisan queue:work
