I have a new instance of IN v5 on a dedicated server running CentOS Web Panel that I can not get the CRONS to work. I also have another instance of IN v4 running on the same machine where the CRONS have been working great for years. I thought I could use the same CRON code but just change the domain/location and everything would work. Example of what is working in IN v4…
The cron job in v5 needs to run every minute. You should replace the “0” at the beginning of the line with a “*”. (After that it takes one UTC midnight pass-through for the red triangle to disappear.)
I added the star at the beginning so it runs every minute. That seemed to have worked to get rid of the error in the GUI but now none of my re-curing invoices seem to be sent out. They are stuck on “Pending” and not sending.
