techwiz
1
Just migrated to v5.5.17 from v4.5.50
It seems that the initial credit amount and the balance columns are reversed.
In addition it seems the dates have been stripped.
V4
V5
Is there a way to fix this?
Can anyone else confirm they are having this issue?
techwiz
3
If I simply rename the amount and balance columns in the database will that have any other detrimental effect? Because that seems to work for now…
4
I wouldn’t advise that, it will most likely cause problems
techwiz
5
I will stay tuned for a more complete solution.
As we’ve been using the new version this week going back to v4 is a less viable option at this point.
david
6
@techwiz
Are they literally a mirror image? amount <> balance?
techwiz
7
As far as I can tell, yes.
