Credit Card Icons in React
Since getting 5.9.2 up and running, I kept getting the notice to switch to the React web app so I did it. Takes a bit of practice to adjust but I noticed that the credit card icons are broken in the client view. It links to mysite.com/gateway-card-images/visa.png but has a broken icon. I can find the images in public/images/visa.png and public/assets/assets/images/payment_types/visa.png. Any idea?
Tasks show as logged which is confusing. I can click to change it but have to guess which status it is currently on. Plus it would be nice if tasks didn’t get their hours overwritten when picking a service type when invoicing.
Thanks for reporting this!
cc @david @ben
@Ryan_G
have you installed in a subdirectory?
I’m not quite sure how to answer the question. I believe it is at defaults.
Ubuntu 20.04
Install is at /usr/share/nginx/invoiceninja
Config is at /etc/nginx/conf.d/invoiceninja.conf
@Ryan_G
Are you using a custom configuration file for your nginx?
your try_files should be hitting that static resource.
you’ll want to ensure the root parameter of your nginx configuration points to the /public folder
you’ll also want to make sure
location / {
    try_files $uri $uri/ =404;
If the first attempted block in the nginx configuration.
also
It was set as the following
location / {
I changed it to
location / {
Nothing changed it seems. Here is my current location block in etc/nginx/conf.d/invoiceninja.conf
location / {
if (!-e $request_filename) {
location ~ .php$ {
fastcgi_split_path_info ^(.+.php)(/.+)$;
# Here we pass to php-fpm listen socket. For configuration see /etc/php-fpm.d/*.conf.
fastcgi_pass unix:/run/php/php8.3-fpm.sock;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
location ~ /.ht {
deny all;
location = /robots.txt { access_log off; log_not_found off; }
Ok, lets rewind second. Can you share a screenshot of where the card logos appear broken?
