@hillel and it is possible in company address change city/zipcode to zipcode/city?
in portugal first come zipcode
or maybe it is easier make a custom field?
Yeah… I worked like 4h+ on this problem. And also agree that it’s not worth the time anymore, as none of my invoices ever reached the end.
I have a custom design based on hipster but modern provides a good example for fixed footer. What I found out is that if you change
[data-ref="table"] {
margin-bottom: 1rem;
It alters the layout at the bottom. But also alters the hole table that I don’t want.
Modern uses a footer-spacer but I also cant make it work right. I think the best way would be a spacer container attached to the fixed footer, but than margin is not working (because of fixed property)
