I’m confused in about how to create a credit nota.
I have an invoice that’s only paid partly. I want to credit the unpaid part.
For accounting I also need to have an official PDF to indicate the credit.
I created a negative invoice. The title is marked as CREDIT NOTE correctly and the amount is negative. So that’s as expected. But both the negative invoice as the partly paid invoice are now still marked as unpaid? The Credit nota doesn’t get calculated with the payed one?
I tested the Credit part of invoice ninja before and I saw you can use that amount as credits to mark an invoice as paid, but:
a) I can’t generate a PDF of it.
b) If I add a credit part for the same customer, the credit is applied 2 times/double and my credit nota is still marked as unpaid?
Yes, then I do get a credit added under credit nota’s, but negative.
So when I go to the original invoice and try to add a “payment” I get the message that there are not enough credits to do this:
Error I receive when trying to mark the partial unpaid invoice as payed:
The credit nota that’s indeed now ended with balance 0:
Wouldn’t it be logical if marking or even creating a credit nota (so a negative invoice) creates a credit that you can use to mark another invoice (partly) as paid? Or where do you use the credits for?
