I am testing your app (on invoiceninja.com) right now. Still on on trial period, so have PRO version options.
I chose your app because you said that it is possible to customize template or create our own.
But in Customize panel, I can’t make changes as :
add text
create header
split the footer in 2 columns
apply different font on a specific part
Do I miss something?
Could you please help me on that?
I know HTML, PHP and CSS (but not very well JS)
Waiting help/reply on that issue, because if I can’t modify design, I will have to pick another app/software
Thanks and regards
