Create Default Terms
In V4 I could save as default terms but in v5 this option is gone
You can set the default invoice terms on Settings > Company Details > Defaults.
Note: in v5 we’ve added a search for the settings which can be helpful.
@david any thoughts?
Thank you.
You may need to save the invoice for the terms to be applied. If that’s the case we should show the default terms as a placeholder to make it clearer.
