What is the best method to backup IN v5?
When I take a backup of the .env file and a MySQL dump, do I then have everything to do a restore? Are eg. all the uploaded files stored in the database? Is something else stored on the file system?
Good idea.
I also take daily snapshots of my servers, but they are stored on the same physical location as the VM itself. So I also take my own backups and store them on 2 different locations. But to script that, I had to know what exactly what exactly needs to be backed up.
Hi @KrisL Was wondering if your backups are going ok? New to Linux here was trying to find out my self on what or how the best way to perform backups … When using scripts do you need to stop services for InvNinja, database, etc before making copies? or does it allow you to copy?
I have several bash scripts to create and store local back-ups of the database and the files, which I back-up again each night to another off-site location. The local back-ups are just the back-ups of the last two days and used for a quick restore. The off-site back-ups are stored several weeks and are encrypted.
To back-up the InvoiceNinja database, you can stop the application so it doesn’t write things to the database at the same time. But when you create the back-up at down hours, eg nightly, you can just run mysqldump. Eg:
Hi David, can you tell me how to do that. If I did not set up the smtp email server in the env file? Cause when I want to export a JSON File I get the notification that an email with a link was send. Logically this email will never reach out to me. Any solution for that? Thanks a lot!!
