Just a quick question - if we set the reset counter on ‘Annualy’ what is the desired effect here? Is it one year from now or is it at the turn of the year?
Br, Z
Br, Z
At the start of the year
Thank you. It would seem ours didnt reset… how does ninja reset the counter?
Do you have the crons enabled
https://invoice-ninja.readthedocs.io/en/latest/configure.html
Not sure what your asking. Cron is enabled and active on our server.
Have you enabled the send-invoices and send-reminders crons per the docs?
Aaah so they have to both be enabled in order for the reset counter to work… will do.
