Is it possible to add a custom field to add a name and signature option on Task and Invoice, like using the stylus to sign or draw
The app supports adding custom fields but I’m not sure what you mean by using a stylus.
Note: there is a signature option on Settings > Client Portal.
It is like a pen on paper users will sign
I suggest trying the signature feature to see if it works for you.
