In version 4, when a quote was approved the user was redirected to its converted invoice. In version 5 that redirect doesn’t happen. Instead the page reloads with the approved quote and a notice is shown saying ‘Only quotes with “Sent” status can be approved.’. There also is no button/CTA prompting the user to view the corresponding invoice like there was in version 4. Is there a setting that I’m missing to enable the behavior that used to happen in version 4.
If you convert the quote while viewing it you should see a link to view the new invoice. If you convert it while editing there isn’t currently a link but we can look into adding one.
@david are we able to adjust the app to allow converting draft quotes?
