Hi, my browser continuously download PDFs of the invoices or items that I am busy with during normal use. PDFs are just called pdf with no extension. I use Firefox on Linux.
From further investigation, it seems like it downloads it in an attempt to render a preview. Unfortunately, this makes editing invoices impossible.
Firefox v100.0 (64bit) on Manjaro Linux
JM
It should help to enable the alternate PDF viewer on Settings > Device Settings.
It is doing this on the web version today too. Nearly drove me insane. I kept having to click back into each field multiple times in order to type. Generated 44 PDFs in the course of creating a 5 line invoice.
Great, I just disabled it at first which worked… But did test the alternative and it seems to be working. Thx
OK, so disabling Show PDF Preview should fix it?
Note: the underlying problem is most likely due to a browser setting preventing the native renderer from showing the PDF. The alternate renderer is a workaround but the native renderer is a bit better.
https://support.mozilla.org/en-US/questions/985483
