Configuring Invoices for Rental Equipment and Labor
Hi there, I’m new to Invoice Ninja, but it seems like a powerful program.
I am having troubling configuring my invoices to fit my business i.e. a mix of rentals and labor, typically on the same invoice.
For products (the equipment I rent), I added a single line text custom field called “Days”.
For renting equipment, I need the cost, quantity, days rented, and a discount field.
However, the “Days” field doesn’t contribute to the total cost of the product.
What am I missing?
For labor, rates vary job to job and I think I will manually have to enter the rate/hours depending on what was negotiated and add labor as a “Task”. Is there a better way to do this?
Thanks for the help.
+W
Welcome! The app doesn’t support including a custom field in the invoice calculation. I think you’d need to store qty * days in the qty field.
Tasks are mainly designed to be used as work timers, if you’re manually entering the amounts it may be easier to use products.
Understood, thank you.
The reason I was thinking Tasks is because we often have discounts on our products and charge sales tax, but we do not discount labor and it’s formatted as a different section. Not sure how to make different sections within the invoice with different subtotals.
Hmm.. tasks would give you a different section on the invoice but not the subtotals.
Another option may be a custom template:
