Hello @ all,
sorry for opening a thread for this, but I cannot find a complete list of all available custom fields for Invoice-Templates.
By the way: What’s the difference between a template and a design?
Regards
Hello @ all,
Regards
Here’s the list of fields:
Templates are more flexible than designs, this video provides a good overview:
Hi Hillel,
I already found that list before I opened this topic. I thought it was not complete.
However I also watch that video, but where can I get the syntax or the variable lists for that all? What does it mean to set { } brackets or double {{ }} brackets? When to write % and when not. Are spaces between brackets and values necessary? And so on.
Do you have a manual for that?
Thanks a lot!
If you’re aware of any fields which are missing we’re happy to add them.
You can refer to the TWIG documentation for specifics: https://twig.symfony.com
Thanks, that’s cool. But where do I get the variables and stuff?
The variables are listed in the page linked above, unless I’m misunderstanding?
I mean those one must use for the TWIG stuff. Like
{ item.notes }
{{ % set invoice = invoices|first }}
‘n’ stuff. I’m sorry, maybe I’m slowly in understanding it all.
You can use the API docs to reference the object fields. For example, at the bottom of this page check out example/schema section.
Hey @hillel , I am missig a few fields:
Taxes 1/2/3
I can’t seem to find how to access individual Total Tax Names and Amounts. All I found is
$total_tax_labels and $total_tax_values, but I need them separated for each Tax 1, 2, 3,. Can you please let me know the variable used to access them?
Client/Contact Email
Also, $client.email is not working for me, despite having a contact added to the client / invoice. This one is in the documentation as an alias of $email so it should work.
Net Amount
Have tried a number of variations but can’t get it to work.
Would appreciate your help very much. Thanks in advance!
Hi, I suggest asking in a discussion on GitHub.
OK, thanks. I’ve done so.
