I have installed InvoiceNinja in my Hostinger Shared Hosting using their Auto Installer. And when I try to generate an invoice, I get
Error 500:
Here is my .env file:
APP_NAME="Invoice Ninja"
APP_ENV=production
APP_KEY=<redacted>
APP_DEBUG=false
APP_URL=https://wayhike.in/invoice
DB_CONNECTION=mysql
MULTI_DB_ENABLED=false
DB_HOST=127.0.0.1
DB_DATABASE=<redacted>
DB_USERNAME=<redacted>
DB_PASSWORD='<redacted>'
DB_PORT=3306
DEMO_MODE=false
BROADCAST_DRIVER=log
LOG_CHANNEL=stack
CACHE_DRIVER=file
QUEUE_CONNECTION=sync
SESSION_DRIVER=file
SESSION_LIFETIME=120
REDIS_HOST=127.0.0.1
REDIS_PASSWORD=null
REDIS_PORT=6379
MAIL_MAILER=smtp
MAIL_HOST=<redacted>
MAIL_PORT=<redacted>
MAIL_USERNAME=<redacted>
MAIL_PASSWORD=<redacted>
MAIL_ENCRYPTION=SSL
MAIL_FROM_ADDRESS='<redacted>'
MAIL_FROM_NAME='<redacted>'
POSTMARK_API_TOKEN=
REQUIRE_HTTPS=true
GOOGLE_MAPS_API_KEY=
ERROR_EMAIL=
TRUSTED_PROXIES=
NINJA_ENVIRONMENT=selfhost
#options - snappdf / phantom / hosted_ninja
PDF_GENERATOR=phantom
PHANTOMJS_KEY='<redacted>'
PHANTOMJS_SECRET=secret
UPDATE_SECRET=secret
COMPOSER_AUTH='{"github-oauth": {"github.com": "${{ secrets.GITHUB_TOKEN }}"}}'
SENTRY_LARAVEL_DSN=https://3<redacted>@sentry.invoicing.co/9
OPENEXCHANGE_APP_ID=<redacted>
And here is my .htaccess:
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /invoice
RewriteRule ^$ index.php [R=301,L]
RewriteRule ^deleteme\.\w+\.php - [L]
RewriteRule "^.env" - [F,L]
# RewriteRule "^storage" - [F,L]
RewriteRule ^(.well-known)($|/) - [L]
RewriteRule ^(.*)$ public/$1 [L]
</IfModule>
# https://github.com/h5bp/server-configs-apache/blob/master/dist/.htaccess
# # INTERNET EXPLORER #
# | Iframes cookies |
# Allow cookies to be set from iframes in Internet Explorer.
# https://msdn.microsoft.com/en-us/library/ms537343.aspx
# http://www.w3.org/TR/2000/CR-P3P-20001215/
<IfModule mod_headers.c>
Header set P3P "policyref=\"/w3c/p3p.xml\", CP=\"IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT\""
</IfModule>
# # MEDIA TYPES AND CHARACTER ENCODINGS #
# | Character encodings |
# Serve all resources labeled as `text/html` or `text/plain`
# with the media type `charset` parameter set to `UTF-8`.
# https://httpd.apache.org/docs/current/mod/core.html#adddefaultcharset
AddDefaultCharset utf-8
# Serve the following file types with the media type `charset`
# parameter set to `UTF-8`.
# https://httpd.apache.org/docs/current/mod/mod_mime.html#addcharset
<IfModule mod_mime.c>
AddCharset utf-8 .atom \
.bbaw \
.css \
.geojson \
.js \
.json \
.jsonld \
.manifest \
.rdf \
.rss \
.topojson \
.vtt \
.webapp \
.webmanifest \
.xloc \
.xml
</IfModule>
# # WEB PERFORMANCE #
# | Compression |
<IfModule mod_deflate.c>
# Force compression for mangled headers.
# https://developer.yahoo.com/blogs/ydn/pushing-beyond-gzipping-25601.html
<IfModule mod_setenvif.c>
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Map certain file types to the specified encoding type in order to
# make Apache serve them with the appropriate `Content-Encoding` HTTP
# response header (this will NOT make Apache compress them!).
# If the following file types wouldn't be served without the appropriate
# `Content-Enable` HTTP response header, client applications (e.g.:
# browsers) wouldn't know that they first need to uncompress the response,
# and thus, wouldn't be able to understand the content.
# http://httpd.apache.org/docs/current/mod/mod_mime.html#addencoding
AddEncoding gzip svgz
</IfModule>
# Compress all output labeled with one of the following media types.
# IMPORTANT: For Apache versions below 2.3.7 you don't need to enable
# `mod_filter` and can remove the `<IfModule mod_filter.c>` & `</IfModule>`
# lines as `AddOutputFilterByType` is still in the core directives.
AddOutputFilterByType DEFLATE "application/atom+xml" \
"application/javascript" \
"application/json" \
"application/ld+json" \
"application/manifest+json" \
"application/rdf+xml" \
"application/rss+xml" \
"application/schema+json" \
"application/vnd.geo+json" \
"application/vnd.ms-fontobject" \
"application/x-font-ttf" \
"application/x-web-app-manifest+json" \
"application/xhtml+xml" \
"application/xml" \
"font/opentype" \
"image/svg+xml" \
"image/x-icon" \
"text/cache-manifest" \
"text/css" \
"text/html" \
"text/javascript" \
"text/plain" \
"text/vtt" \
"text/x-component" \
"text/xml"
</IfModule>
</IfModule>
I checked with Hostinger that mod_rewrite is enabled by default for all accounts. But I am seeing index.php in my URL. I also noticed while logging that the URL of the image works if I change the URL to …public/storage/… instead of just …/storage/…
Any suggestions on how to fix this issue?
