InvoiceNinja 6.5.11
Debian 8 Linux
I just recently ran a apt update and apt upgrade. It seemed to have upgraded my php from 7.0 to 7.3.3.
When trying to run the following, I get the error:
Wed, 13 Mar 2019 16:03:10 +0000 Running SendRecurringInvoices...
Wed, 13 Mar 2019 16:03:10 +0000 112 recurring invoice(s) found
Wed, 13 Mar 2019 16:03:18 +0000 0 recurring expenses(s) found
Wed, 13 Mar 2019 16:03:18 +0000 Done
Wed, 13 Mar 2019 16:03:19 +0000 Running SendReminders...
Wed, 13 Mar 2019 16:03:19 +0000 1 due recurring invoice instance(s) found
In Builder.php line 1229:
compact(): Undefined variable: operator
How can I fix this?
March 13, 2019, 5:23am
PHP 7.3 isn’t yet supported
Okay thanks.
I noticed in your docs:
The applications requires PHP >= 7.0.0 and MySQL.
But I guess it should say PHP >=7.0.0.0 < 7.3.0.0
March 13, 2019, 5:35am
4
Yeah, they’re just out of date
March 13, 2019, 5:56am
6
Not sure, 7.2 should work. You may want to try 7.1 as this is likely related to 7.2.
Yup that works.
Thank you.
I guess I won’t be doing any php updates for now.
I had the same problem with builder.php after migrating to 4.5 but i didn´t want to install another or old php version. I solved this when i changed the line in vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php
from
$this->wheres[] = compact('type', 'operator', 'query', 'boolean');
to
"$this->wheres[] = compact('type', 'query', 'boolean');
The reminders are send and the problem is gone.
