Is there a way to add comment lines between products lines. Example Comment Emergency Exit Device for door 38 Then add item under add product and description
Comment Main office door 25 Then add item under add product and description
Example screenshot
This may be possible using a custom template.
I appreciate your comment, I’ll look into custom template. Thank you hillel
Good luck! They’re just plain HTML/CSS, ChatGPT and the like can be helpful in generating them.
