Hi @hillel,
I do a really hard testdrive with reallife workflow on the new and really forward thinking Invoice Ninja but I also find some unpolished corners around there. As they are:
Clients View (Feature Request: Task-Rate should be integrated in the Columns-List as they are in Task-Views):
I’ve added the task rate column to the client table and removed the duplicate client/project columns from the tasks table. For the rate field on the tasks table I believe you can use the “Calculated Rate” field to see that.
updated to 5.1.12 v5-stable today and tested above mentioned issues:
Client View:
Task-Rate is not available.
Task View:
Rate is showing 0,00 € – although Client- and Project-Rates are defined, why? For this Calcuated Rate seems to work as intended: pulls Project-Rate over Clients-Rate which is perfect.
I have got the task rate working – thank you very much for your explanation and your patience!
The other issues I will test with every new release as I plan not to go into production before beta is clear stable.
In the Task View a would expect this one (ID Number) – I use these 4 charakter wide unique Abbreviation of the clients name which combines to a project number like {$client_id_number}_{$client_counter}.
Hi @hillel, sorry for being unprecise: I mean the Task Table/View should have the Project number set via gerated numbers. This should help to identify single projects. As I have hundreds of “Flyer Tradeshow” but only one e.g. “TSRT_0002 Flyer Tradeshow”.
I am very happy with the latest 5.1.26 stable and appreciate the huge amount of work you put into IN and the community communication. I still do in-depth-testing and wanted to to follow up the column name issues: I think everything is now fine except the project view.
