CLIENTS: enabling the option to have separate name fields for billing and shipping for the same client
Certain major clients utilize a different company for invoice payments and stipulate that all invoices, quotes, and related documents include references to both entities. Currently, the client database permits the entry of a single client name along with two distinct addresses for shipping and billing purposes. Could you please incorporate additional name fields under the billing and shipping sections? Additionally, it would be beneficial to include a field for assigning a simple internal name for each client. Thank you!
Maybe you can use custom fields for this?
thanks for quick feedback, that should work indeed, let me check!
Cheers
ok, it’s possible but not practical with custom fields because they don’t appear in the addresses tabs…
This how I would see it
and this is how it appears with custom fields, it’s not optimum
In the latest version of the web app there’s a new ‘Locations’ feature which may help.
I’m currently using the self hosted version on a Synology, but it’s gone wild and just shows a white page since a few weeks. So, I had to switch to the Apple app instead…
Please check the browser console for any errors and create an issue on GitHub
