Client portal url is incorrect
v5.8.28-C156
Docker Installation
During the initial setup I fat fingered the url in Setting>Advanced Settings>Client Portal>Domain URL. I discovered the problem and corrected it, however, the links did not update. When creating a new client or when testing an already created client the base url is still the incorrect one. I can correct it in the address bar and the page pulls up and is navigable. The logo file location also appears to be linking to the incorrect url. I realized from reading similar post that url entry is not needed unless iframes are being utilized so, I removed it but that didn’t make a difference. Can someone tell me were this link is stored so that I can manually correct it? Thanks in advance for any help provided.
You can update the APP_URL value in the .env file.
I don’t know how I missed that. However, my logo is still not loading. It seems to be pointing at that old miskeyed url. Any suggestions?
It should help to upload the logo again.
I did try deleting and uploading the logo more than once to no avail. What did work though, was deleting it then renaming the file and uploading the file with the new name.
I still can’t believe I missed the misspelling in the env file. I guess after staring at the forest for to long the trees become less obvious. :melting_face:
Thank you for your help!
