Hi
Where can I translate client portal locally? I tried editing texts.php but it don’t update any string.
You can define custom translations in the app on Settings > Localization.
If you change the code you’ll lose the changes when you update the app.
Hi does this work on admin panel? Because when i change etc.Recurring Invoices it doesn’t display my translation. Plus i cannot find Purchase Orders variable in texts.php
These changes affect the PDF and client portal but not the admin portal.
Can i change admin translation i any other way?
For the Flutter app you would need to rebuild it, it may be easier with the React app.
Ok thanks i maybe look this up later.
But when i changed password, email_addres and client_portal labels it doesn’t change the translation on login screen to the client portal.
I’m not sure this will work on the login screen since it defaults to English.
@david any thoughts?
if you pass the locale in to the query ie ?locale=de the page will translate automatically to that language. else we use the system default language.
The ?locale=pl parameter doesn’t work. Instead i need to use ?lang=pl. Can i set client portal link to always have ?lang parameter?
If your default language is pl, i believe if you set your country language to this, the client portal should default to this.
I have sl - slovenian and also do not work.
@pcstran
in your .env set
DEFAULT_LOCALE=sl
Gracieeeeeee my friend
