I’m trying to configure the Client Portal.
The idea being that admin access is at sub1.domain.com and the client portal being at sub2.domain.com. However, sub2.domain.com displays the same content as sub1.domain.com (the admin page) rather than the client login screen.
The client domain is set in Advance Settings > Client Portal > Domain URL as “sub2.domain.com”.
Both sub1 & sub2 are pointed at the same folder (/home/invoiceninja)
Any advice is greatly appreciated.
david
3
The client portal isn’t controlled by the domain name as such, it is controlled by the route /client
So if you reach sub2.domain.com/client you’ll hit the client portal.
The app hasn’t been designed to allow root domain / access for the client portal unfortunately.
Okay, I can probably work around that with some rules here or there.
Secondary problem: Links within emails sent to clients still refer to sub1, is there any way to ensure they refer to sub2?
david
5
@danielennistv
yes, this is a known issue, I have it on my backlog when i get around to this.
