Raki
1
if someone create an account as a client, the website is always use “Country: AF” as default. Any way to disable that? For example: Let it empty?
Plus: How I can deactivate the consent-layer? It’s from invoiceninja, but I’m already use the white label.
ben
3
Hey there, thanks for suggesting these. Do you have GitHub account? Can you make this feature request?
If you don’t have a GitHub account, please let us know here so I can do it for you. Thanks.
Raki
4
Which one? To deselect Country AF, deactivate consent layer or both?
ben
6
Both is fine. If you are able to do it as separate issues, that’d be awesome. Thanks.
Raki
7
ben
8
That’d be awesome, thanks.
