Hello I am self-hosting an instance of invoiceninja. Everything is working swell except for the client password reset. I can create a client, give said client a password, then i can go to the client/login and login to the client side portal without any problem. When i navigate to the client/login page and click the “recover your password”, i get the reset email but when i click on the “reset” button i get a "sorry the page you are looking for could not be found. I am looking at my apache logs and i don’t see any entries in the log file that would shed any light on the situation. Any help or suggestions would be greatly appreciated. Thank you.
Sorry I should have mentioned in my orginal post that I did check my .env file and the APP_URL is correct. I’ve tried using incognito mode and non incognito mode when clicking the link and still nothing works.
Also, I can’t reset the regular user (???) passwords either. I’m pretty sure I screwed up my personal user password when I set it up a couple of days ago and had to reset it. it worked then, but I’m not a 100% positive I clicked the reset link either.
Here is the debug info i get when i turn debug on:
(1/1) NotFoundHttpException
in RouteCollection.php (line 179)
at RouteCollection->match(object(Request))
in Router.php (line 546)
at Router->findRoute(object(Request))
in Router.php (line 525)
at Router->dispatchToRoute(object(Request))
in Router.php (line 511)
at Router->dispatch(object(Request))
in Kernel.php (line 176)
at Kernel->Illuminate\Foundation\Http{closure}(object(Request))
in Pipeline.php (line 30)
at Pipeline->Illuminate\Routing{closure}(object(Request))
in Debugbar.php (line 51)
at Debugbar->handle(object(Request), object(Closure))
in Pipeline.php (line 148)
at Pipeline->Illuminate\Pipeline{closure}(object(Request))
in Pipeline.php (line 53)
in CheckForMaintenanceMode.php (line 46)
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
in HandlePreflight.php (line 46)
at HandlePreflight->handle(object(Request), object(Closure))
in Pipeline.php (line 102)
at Pipeline->then(object(Closure))
in Kernel.php (line 151)
at Kernel->sendRequestThroughRouter(object(Request))
in Kernel.php (line 116)
at Kernel->handle(object(Request))
in index.php (line 51)
