Version: v5.10.31
Environment: Docker
Problem: Client portal not working
IN does work fine behind reverse proxy. The IN client portal however is not working. Images and CSS Files use the internal Proxy-URL of the Docker-Container (http://127.0.0.1:8888) within the delivered html data in browser and so the Client portal presentation is broken.
This is my env - file (the relevant part of it):
# IN application vars
APP_URL=https://external.domain.tld
APP_KEY=base64:$valid.app.key=
APP_DEBUG=true
REQUIRE_HTTPS=false
PDF_GENERATOR=snappdf
TRUSTED_PROXIES='*'
My docker-compose.yml:
version: '3.7'
services:
server:
container_name: ninja_web
image: nginx
restart: always
env_file: env
volumes:
- ./docker/app/public:/var/www/app/public:ro
depends_on:
- app
ports:
- "127.0.0.1:8888:80"
networks:
- invoiceninja
app:
container_name: ninja_app
env_file: env
restart: always
volumes:
- ./config/php/php.ini:/usr/local/etc/php/php.ini
- ./config/php/php-cli.ini:/usr/local/etc/php/php-cli.ini
depends_on:
- db
networks:
- invoiceninja
db:
container_name: ninja_db
image: mysql:8
restart: always
env_file: env
volumes:
- ./docker/mysql/data:/var/lib/mysql:rw,delegated
- ./docker/mysql/bak:/backups:rw
- ./config/mysql/backup-script:/etc/cron.daily/daily:ro
- ./config/mysql/backup-script:/etc/cron.weekly/weekly:ro
- ./config/mysql/backup-script:/etc/cron.monthly/monthly:ro
networks:
- invoiceninja
networks:
invoiceninja:
Workaround: configure text-replace in nginx-Config on the host:
server {
listen 1.2.3.4:80;
server_name external.domain.tld;
return 301 https://$host$request_uri;
server {
listen 1.2.3.4:443 ssl;
ssl_certificate /etc/ssl/private/external.domain.tld/bundle.pem;
ssl_certificate_key /etc/ssl/private/external.domain.tld/external.domain.tld.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers HIGH:!aNULL:!MD5;
root /var/www/empty;
location / {
proxy_pass http://127.0.0.1:8888;
sub_filter_once off;
sub_filter_types text/html;
sub_filter "http://127.0.0.1:8888" "https://external.domain.tld";
With this workaround, the client portal works fine. But this is obviously not a clean way to configure it.
I’m expecting that the links and content elements within the client portal use the APP_URL environment variable from the docker configuration. Or is my configuration wrong?
Here’s a link to the incorrect html output:
