Client number not generating how it should be
Hi, I have set up the client number expected as ( WM0-101, WM0-102, and WM0-103 ). but instead of these, I’m getting these (screenshot attached). also, I have set up 2 clients group but I didn’t change any generated number pattern for groups.
please let me know what could be the issue
I believe this can happen if the app is trying to create a number which already exists, it may help to increase the counter in the settings.
I already purge all data and tried but had no luck, however, I have sorted by placing {$counter} before the format. ABC- {$counter}. i missed that counter. it works fine
Glad to hear it’s sorted, thanks for the update!
