I am self hosting. v4.5.9. If you log into client/login it doesn’t show invoices for the person. Also if I reset the password from the client edit it doesn’t update the log in password.
Are the invoices marked as sent?
Yes. If I use the dedicated link to the invoices it works as expected.
The dedicated link works for draft invoices however the invoice needs to be marked as sent for it to be visible in the portal without the direct link.
AFAIK they’re marked as sent. It also doesn’t pull up any previous information on the client. Like how much has been spent and so on.
Do you see a mark sent option on the edit invoice page?
Are you displaying the portal in an iframe? Maybe the top navigation is hidden.
