ClickUp Integration?
Greetings all,
So I’m a bit confused. I’ve got an account setup with ClickUp and was looking for an invoicing solution. I saw that InvoiceNinja was offering a Pro account to integrate with ClickUp and It hough 'Great! Just what I needed". So I created my account. Now I can’t find a single documentation on how to integrate anything nor do I see any references to ClickUp anywhere I’ve looked.
ClickUp doesn’t list InvoiceNinja. So what am I missing here?
The app doesn’t have a direct integration but you could use an app like Zapier
https://zapier.com/apps/clickup/integrations/invoice-ninja-v5
While InvoiceNinja sounds like a great solution, it’s possible that their integration with ClickUp isn’t fully supported yet, or they might have a different approach than what you expected.
I’d recommend checking both platforms’ support sections or reaching out to their customer support directly to get clarity on the integration process. Sometimes user forums or community discussions can also be a goldmine for tips.
If you’re looking for ways to save, don’t forget to check for clickup discounts that might help with any additional features or tools you decide to use.
