After updating the files to latest 4.1.5, I am now getting the error:
PHP message: PHP Fatal error: Uncaught ReflectionException: Class LaravelCrawlerDetect does not exist in /var/www/clients/client1/web2/web/bootstrap/cache/compiled.php:1479
I tried reverting to the former version, but the same error comes up. I also tried fresh upload of the latest files but I get the same error.
dieter@yoda:/srv/ninja/code$ composer install
Loading composer repositories with package information
Installing dependencies (including require-dev) from lock file
Package operations: 29 installs, 0 updates, 0 removals
Installing codeception/c3 (2.0.14): Loading from cache
[codeception/c3] Copying c3.php to the root of your project…
[codeception/c3] Include c3.php into index.php in order to collect codecoverage from server scripts
Installing symfony/dom-crawler (v3.4.0): Loading from cache
Installing symfony/browser-kit (v3.4.0): Loading from cache
Installing stecman/symfony-console-completion (0.7.0): Loading from cache
Installing sebastian/diff (1.4.3): Loading from cache
Installing sebastian/recursion-context (1.0.5): Loading from cache
Installing sebastian/exporter (1.2.2): Loading from cache
Installing sebastian/comparator (1.2.4): Loading from cache
Installing phpunit/php-text-template (1.2.1): Loading from cache
Installing doctrine/instantiator (1.0.5): Loading from cache
Installing phpunit/phpunit-mock-objects (2.3.8): Loading from cache
Installing sebastian/version (1.0.6): Loading from cache
Installing sebastian/global-state (1.1.1): Loading from cache
Installing sebastian/environment (1.3.8): Loading from cache
Installing phpunit/php-timer (1.0.9): Loading from cache
Installing phpunit/php-file-iterator (1.4.5): Loading from cache
Installing phpunit/php-token-stream (1.4.11): Loading from cache
Installing phpunit/php-code-coverage (2.2.4): Loading from cache
Installing webmozart/assert (1.2.0): Loading from cache
Installing phpdocumentor/reflection-common (1.0.1): Loading from cache
Installing phpdocumentor/type-resolver (0.4.0): Loading from cache
Installing phpdocumentor/reflection-docblock (4.2.0): Loading from cache
Installing phpspec/prophecy (1.7.3): Loading from cache
Installing phpunit/phpunit (4.8.36): Loading from cache
Installing facebook/webdriver (1.5.0): Loading from cache
Installing behat/gherkin (v4.4.5): Loading from cache
Installing codeception/codeception (2.3.3): Loading from cache
Installing phpspec/php-diff (v1.0.2): Loading from cache
Installing phpspec/phpspec (2.5.8): Loading from cache
phpunit/phpunit-mock-objects suggests installing ext-soap ()
sebastian/global-state suggests installing ext-uopz ()
phpunit/php-code-coverage suggests installing ext-xdebug (>=2.2.1)
phpunit/phpunit suggests installing phpunit/php-invoker (~1.1)
codeception/codeception suggests installing codeception/specify (BDD-style code blocks)
codeception/codeception suggests installing codeception/verify (BDD-style assertions)
codeception/codeception suggests installing flow/jsonpath (For using JSONPath in REST module)
codeception/codeception suggests installing league/factory-muffin (For DataFactory module)
codeception/codeception suggests installing league/factory-muffin-faker (For Faker support in DataFactory module)
codeception/codeception suggests installing symfony/phpunit-bridge (For phpunit-bridge support)
phpspec/phpspec suggests installing phpspec/nyan-formatters (~1.0 – Adds Nyan formatters)
Package chumper/datatable is abandoned, you should avoid using it. Use OpenSkill/Datatable instead.
Package guzzle/guzzle is abandoned, you should avoid using it. Use guzzlehttp/guzzle instead.
Package illuminate/html is abandoned, you should avoid using it. Use laravelcollective/html instead.
Package league/url is abandoned, you should avoid using it. Use league/uri instead.
Generating optimized autoload files
> php artisan clear-compiled
PHP Fatal error: Uncaught ReflectionException: Class LaravelCrawlerDetect does not exist in /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Container/Container.php:749
Stack trace: #0 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Container/Container.php(749): ReflectionClass->__construct(‘LaravelCrawlerD…’) #1 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Container/Container.php(644): Illuminate\Container\Container->build(‘LaravelCrawlerD…’, Array) #2 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(709): Illuminate\Container\Container->make(‘LaravelCrawlerD…’, Array) #3 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Container/Container.php(1203): Illuminate\Foundation\Application->make(‘LaravelCrawlerD…’) #4 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(175): Illuminate\Container\Container->offsetGet(‘LaravelCrawlerD…’) #5 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(144) in /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Container/Container.php on line 749
Script php artisan clear-compiled handling the post-install-cmd event returned with error code 255
/* use Crawler;*/ in app/Exceptions/Handler.php
// if (Crawler::isCrawler()) {
// return false;
Nothing to install or update
PHP Fatal error: Uncaught Error: Call to undefined method Illuminate\Support\Facades\Session::get() in /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:237
Stack trace: #0 /srv/ninja/code/app/Libraries/Utils.php(410): Illuminate\Support\Facades\Facade::__callStatic(‘get’, Array) #1 /srv/ninja/code/app/Exceptions/Handler.php(78): App\Libraries\Utils::logError(’***Symfony\Comp…’) #2 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(79): App\Exceptions\Handler->report(Object(Symfony\Component\Debug\Exception\FatalThrowableError)) #3 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->handleException(Object(Symfony\Component\Debug\Exception\FatalThrowableError)) #4 {main}
thrown in /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php on line 237
Stack trace: #0 /srv/ninja/code/app/Libraries/Utils.php(410): Illuminate\Support\Facades\Facade::__callStatic(‘get’, Array) #1 /srv/ninja/code/app/Exceptions/Handler.php(78): App\Libraries\Utils::logError(’***Symfony\Comp…’) #2 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(79): App\Exceptions\Handler->report(Object(Symfony\Component\Debug\Exception\FatalErrorException)) #3 /srv/ninja/code/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(118): Illuminate\Foundation\Bootstrap\HandleExceptions->handleException(Object(Symfony\Component\Debug\Exception\FatalErrorException)) #4 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->handleShutdown() #5 {main}
dieter@yoda:/srv/ninja/code$ sudo chown -R dieter:www-data /srv/ninja/code
The compiled class file has been removed.
> php artisan optimize
Generating optimized class loader
Compiling common classes
