how do I change the URL from “Knowledge Base” on the login page? I’d like to change it to my own.
Thanks for your reply.
You can change the code but we don’t support setting the link in the .env file.
https://github.com/invoiceninja/invoiceninja/blob/master/resources/views/auth/login.blade.php#L80
Note: if you purchase a white label license this link is hidden.
