I have currently an issue and didn’t really find a way to solve it.
Usually when we send out invoices there is a text which says “Rechnung” which basically means invoice in German.
Now what I want to do is, when the invoice gets into past due and gets to send out as a reminder I want it to change to “Mahnung” which basically means “warning or reminder” that’s how it is in Germany.
Its for the pdf files, meaning the text should change in the pdf file its a requirement by law to change the word “Rechnung” to “Mahnung” when the invoice gets past due and past due charges.
hi i found no work around… i`ve testet to set a custom pdf template for reminders, but i can`t found it… i think it is a good solution to extend the Settings > Invoice Template with Reminder Design
