Change signature position on quote
I need to change the signature position on quote.
Following this other post instructions, the current template signature is well hidden.
But my custom design signature does not work. It creates a bug on page : no signature, and all template code appears wrong now.
Could you please help on that ?
I’m not sure, since you’re on the hosted platform I suggest sending an email to [email protected] to ask.
Just sent an email to them. Thanks.
By any chance, would you know how to make “contact signature name” and “signature date” appearing, next to signature ?
I know how to insert these 2 items adding some code after the quote table, but since I can not change signature position right now, I do not know how to place them before the signature original position (which is automatically inserted in the Total Table, on left side of Totals, just after the Terms).
Maybe you can include the text in the terms?
I tried before, adding some code here :
Settings / Company details / Defaults / Quote Terms
My custom code was :
<p class="condition-sign-name">Nom : $contact.first_name $contact.last_name</p>
<p class="condition-sign-date">Date : $contact.signature_date</p>
But customised terms do not accept these kind of code : $contact.first_name
If you’re using variables I think you’d need to add it in a custom design rather than in the terms.
Yes, that’s what I thought. Thanks.
Waiting for a reply from customer service. If they find a solution for signature position, I will post it on this thread.
Here the solution to change signature position on your customised template.
First, hide the original signature by adding this code on CSS file :
    [data-ref="contact-signature"] {display: none;}
If it does not work, this is another way to hide it (this one worked for me) :
#contact-signature {display: none;}
Second, add the new signature at position you prefer on your template body :
<div class="my-new-signature"><img src="$contact.signature"></div>
Third, fix the signature size on CSS file :
.my-new-signature img {max-height: 100px;}
Thanks for sharing the solution!
