Hello. I’ve tried to change every quote label in Spanish by editing /lang/es_ES/texts.php but it produces no effect. Can someone point me in the right direction?
Thanks in advance
Thanks in advance
You can set custom labels in the app on Settings > Localization > Custom Labels.
Thank you. I have also done that and cleared the app cache and browser cache but labels keep showing the same as before. v5.3.29-C62
Which specific label are you referring to? Custom labels will affect the PDF and client portal.
Note: it looks like you’re using a much older version of the app, it may help to upgrade.
Thank you again. The hosting doesn’t meet the requirements for the new version (a PHP 8 extension is missing) I want to Change the word Quote everywhere if possible
Changing the label in the admin portal would require rebuilding the app from source.
