Change hourly to daily rate
Hi all,
i am totally new to invoiceninja and really like all the options possible but still trying to find my way around.
I am working mostly as Audio, Lighting and Videotechnician on a daily basis, not by hour but by daily rate, so i would like to know if there is a possibility to set my invoices as a daily rate instead by hours.
for example, i would like to have all in one line like:
videotechnician | daily rate | days worked | sum of daily rate x days worked.
thanks
jan
The system works with hours as the base unit.
You could update the labels however and replace Hours with Days the app would then work the way you expect.
Hi David, thanks for the reply.
If you could just point me to where i can change the label would be amazing.
Actually i found this in another post.
ninja/resources/lang/en/texts.php
Is it this one? And are there differences between en and de?
You can change the label on Settings > Localization > Custom Labels
When I change a lable name to a custom one, is there a way to change/translate this lable if one client has another invoice language?
Use case: I change ‘hour’ to ‘amount’ (I have to mix daily and hourly rate sometimes because I have days as base but use hours for overtime).
When I create a invoice with a language other than English, the label keeps saying ‘amount’.
Is there a solution for that use case?
One option may be to create separate companies.
My solution was to just enter it as different products with a (day) or (hour) as suffix as I don’t use InvoiceNinja for advanced time tracking anyway
