I would like to change the default labels of the default product fields, not the custom fields.
For example, I would like to change “Unit price” to “price”.
Thanks,
Anna
Thanks,
Anna
This can be accomplished by adding a custom label on Settings > Localization.
Like I mentioned on my post, I do not want to create a new label. I want to change the existing names, for example, i would like to be able to change “total”.
When I enter settings > localization, I only see custom fields. Am I missing something? Could you send me a screenshot?
On Settings > Localizations you can define a custom label to override the default one, this will change the label not add a new field.
