I’m getting the following error when trying to email invoices:
fopen(): SSL operation failed with code 1. OpenSSL Error messages: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
I’ve seen messages you’ve left in the forums referencing solutions to this problem, but I can’t for the life of me find any actual solutions. Can you please point me in the right direction?
June 15, 2016, 7:33am
I’d suggest testing with a different email account, otherwise you can consider disabling these checks:
http://php.net/manual/en/context.ssl.php
Forgive my ignorance-- I’m not that familiar with php. I can see that I would use the verify_peer FALSE context, but I don’t know where to do that.
June 15, 2016, 7:20pm
4
I believe they can be set in the php.ini config file
My solution, for those who also run in to this problem, was fairly straight forward. In the end I didn’t have to modify my php config at all.
I used the tool at this website to see that my ssl cert chain was incomplete.
I’m using nginx, so all I really had to do was concatenate my CA root certificate to the end of my cert file. An embarassingly nooby mistake…
June 18, 2016, 8:29am
6
Thanks for sharing the fix!
