Version
Self Hosted v5.10.40
Environment
Docker
Describe the bug
Any ideas why in the plain theme the categories are not aligned?
No adjustments just using the default theme:
Docker
Can you please explain the screenshot, why are there two table headers?
I am using German translation. It basically is an invoice with products and time-based (task) services. That is why there are two table headers.
I switched now to the bold theme (because of the fixed footer @ bottom issue that still is existing in the plain theme).
Additionally I changed the table width in the CSS to fixed values for the first two columns. Not sure if that is the way to go but it works:
/* Column: Products */
[data-ref="table"] > thead > tr > th:first-child {
width: 28px !important;
/* Column: Description for Products*/
[data-ref="product_table-product.description-th"] {
width: 50%;
/* Column: Description for Tasks*/
[data-ref="task_table-task.description-th"] {
width: 50%;
The following columns adjusted also via CSS:
/* Spalte: Menge */
[data-ref="table"] > thead > tr > th:nth-child(3) {
width: 50px !important;
text-align: center;
[data-ref="table"] > tbody > tr > td:nth-child(3) {
text-align: center;
/* Spalte: E-Preis */
[data-ref="table"] > thead > tr > th:nth-child(4) {
text-align: right;
[data-ref="table"] > tbody > tr > td:nth-child(4) {
text-align: right;
Glad to hear it’s working now, thanks for sharing the solution!
